Old 09-26-2012, 06:41 PM   #1
electrical wiring
is there a code of where you can put an electrical plug (new) how far from a corner, window etc....
pdl57 is offline   Reply With Quote
Old 09-26-2012, 07:22 PM   #2
DIY Enthusiast
sublime2's Avatar
electrical wiring
MAXIMUM distance between outlets is 12ft.
Don't believe there is a minimum.
From a door way,6 ft maximum.
sublime2 is offline   Reply With Quote
Old 09-26-2012, 07:27 PM   #3
joed's Avatar
electrical wiring
There are a certain amount of receptacles required to be installed. Once those have been installed you can install receptacles almost anywhere you want. In a bathtub would not be permitted as one bad example, but floors, ceilings or any place on a wall at any angle you like are permitted.
Do not PM with questions that can be asked in a forum. I will not respond.
How do you work on electrical wiring stuffs when there is insulation in the attic? htabbas Electrical 19 01-08-2012 02:03 AM
Electrical wiring covered by ductwork ok? Ginny28 HVAC 5 01-04-2012 09:20 PM
Schedule 40 PVC in Chicago? franwalker Electrical 56 12-20-2011 11:04 PM
Electrical wiring! Kyle1971 Electrical 7 04-25-2011 05:53 PM
How can I tell if there is electrical wiring beneath kitchen tiles? Mr T Electrical 8 01-04-2009 05:40 PM
