Electrical Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 06-30-2012, 05:42 PM   #1
electrical wiring
How do I install 2 wall switches to control one half of a wall plug. I want to be able to turn the wall plug off from either side of the room.
woodgrove is offline   Reply With Quote
Old 06-30-2012, 08:00 PM   #2
Use three way switches, bring power into the first three way, run xx-3 to the other three way switch, then run from the second switch to the half of the outlet you want switched. The unswitched side could powered from the power feed to the first switch.
Terabitdan is offline   Reply With Quote
How do you work on electrical wiring stuffs when there is insulation in the attic? htabbas Electrical 19 01-08-2012 02:03 AM
Electrical wiring covered by ductwork ok? Ginny28 HVAC 5 01-04-2012 09:20 PM
Schedule 40 PVC in Chicago? franwalker Electrical 56 12-20-2011 11:04 PM
Electrical wiring! Kyle1971 Electrical 7 04-25-2011 05:53 PM
How can I tell if there is electrical wiring beneath kitchen tiles? Mr T Electrical 8 01-04-2009 05:40 PM
