Electrical Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 12-29-2011, 01:34 PM   #1
electrical wiring
I want to know if it worth re-wiring my house wile I have sheet rock down.
The house was built in the early 60's.
It has circuit breakers and 2 conductor 12 gauge wiring with ground, but I have never seen this type of wire. It is labeled "Diamond DTX 12-2-6 Type NM 600 volt".
It is like Romex except it has a cloth like coating instead of PVC.
It is copper wire.
edgodfrey is offline   Reply With Quote
Old 12-29-2011, 01:39 PM   #2
Julius793's Avatar
Is it copper?
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
The Following User Says Thank You to Julius793 For This Useful Post:
edgodfrey (12-29-2011)
Old 12-29-2011, 02:00 PM   #3
yes it is copper.
Old 12-29-2011, 02:25 PM   #4
Rewards Points: 746
One thing that may be an issue is the temperature rating of the cable. If you've ever changed out any fixtures, you'd probably see a label indicating it needs wire rated at 90C. Prior to about '85 60C wire was common.
Is it in good shape? No damage?
Regardless of what you decide to do with the wire, I'd certainly run any additional circuits that you want now or even split up existing circuits if you wish.
AandPDan is offline   Reply With Quote
Old 12-29-2011, 03:09 PM   #5
joed's Avatar
Rewards Points: 12,008
I would not change the exsititng cable unless it was damaged.
Since the walls are open you MIGHT be required to bring everything to current code. If so , that means you might need to add more receptacles if there aren't enough to meet the current 6/12 rule. AFCIs and GFCIs will be required. Neutrals in switch box will be required. TR receptacles.
Schedule 40 PVC in Chicago? franwalker Electrical 56 12-20-2011 11:04 PM
Basement Electrical Wiring Question psqually Electrical 11 05-15-2011 05:18 PM
Electrical wiring! Kyle1971 Electrical 7 04-25-2011 05:53 PM
electrical wiring home ? dcjcdc Electrical 19 07-27-2010 09:38 AM
How can I tell if there is electrical wiring beneath kitchen tiles? Mr T Electrical 8 01-04-2009 05:40 PM
