Electrical Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 11-25-2011, 08:22 PM   #1
Electrical Wiring
I am in the process of replacing an electric stove top with a gas stove top. The gas top requires 120 volt connection. Can I use the same wire (on its own dedicated circuit) and replace the 240 breaker with a breaker that supports 120?
Jcrawf1000 is offline   Reply With Quote
Old 11-25-2011, 08:27 PM   #2
Rewards Points: 150
No...
OhioHomeDoctor is offline   Reply With Quote
Old 11-25-2011, 08:48 PM   #3
Yes, you can down fuse the wiring to a 20amp breaker and swap the wiring to one hot, one neutral and one ground
heartlessmcfly is offline   Reply With Quote
Old 11-25-2011, 09:42 PM   #4
Missouri Bound's Avatar
Probably not if you didn't have a neutral there before.
Old 11-25-2011, 09:45 PM   #5
Rewards Points: 582
do the proper thing and install new 12 -2 wire on 20 breaker to your new cook top so you won't have any problems. best way..right way
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
Jim Port (11-25-2011), Speedy Petey (11-25-2011)
Old 11-25-2011, 09:55 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Originally Posted by OhioHomeDoctor View Post
No...
Care to explain further?
Old 11-25-2011, 09:55 PM   #7
The IS a neutral. It is the ground he may not have.
Old 11-25-2011, 09:56 PM   #8
I fully agree. This way you also still have the existing larger 120/240v line if you ever need it again.
The Following User Says Thank You to Speedy Petey For This Useful Post:
ben's plumbing (11-26-2011)
Old 11-26-2011, 01:36 PM   #9
Electrical Wiring
Thanks for the replies and advise. I do have a second option as I have existing 120 volt outlets already wired to the cooking Island. I just need to determine if the cooktop requires a dedicated circuit.
Basement Electrical Wiring Question psqually Electrical 11 05-15-2011 05:18 PM
Electrical wiring! Kyle1971 Electrical 7 04-25-2011 05:53 PM
electrical wiring new construction 63Falcon Electrical 1 11-07-2010 04:31 PM
electrical wiring home ? dcjcdc Electrical 19 07-27-2010 09:38 AM
How can I tell if there is electrical wiring beneath kitchen tiles? Mr T Electrical 8 01-04-2009 05:40 PM
