electrical wiring
Originally Posted by Speedy Petey
Do you honestly think 75 feet is far enough to warrant over-sizing the wire??
I used #10 for mine, which is the same length, due to at the time I did not know if I was going with a 30 amp, or sticking with a 20 amp. For the price, it was cheaper to go with #10/3 UF.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
