Electrical Wires Near/touching Supply Ducts? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-03-2011, 09:55 AM   #1
Electrical wires near/touching supply ducts?
New to the board. Good to be here. Can electrical be run with (next to, touching, parallel) flex forced air supply ducts?
Borgs8 is offline   Reply With Quote
Old 02-03-2011, 11:04 AM   #2
Rewards Points: 246
Yes, cables and conduits can run parallel to duct work and can touch each other. You cannot use the duct to support the cable though.
Old 02-03-2011, 11:13 AM   #3
many thanks. i am not sure i understand what you mean by "support", however. again, many thanks. my main concern is electrical wires and a junction box touching the flex duct for the forced air heat.
Old 02-03-2011, 11:27 AM   #4
RST
DIY Homeowner
Rewards Points: 150
OP - by "support" he means the duct should not carry the weight of the wire. Wires can not just be hanging in the air. Boring holes in joists (NOT TRUSSES) or using a running board are examples of POSSIBLE acceptable alternatives - check local electrical and building codes.
J.V., does your answer also apply to uninsulated round or rectangular ducts? Or do I need to insulate them first?
RST
RST is offline   Reply With Quote
Old 02-04-2011, 08:26 AM   #5
Scared Electrician
Saturday Cowboy's Avatar
You can run wires in that situation.
In a home there are very few regs relating to separation distance from any thing. There are requirements to derate wire or to use wiring methods acceptable for the location.
But only the Urban Legend Electrical code says things like:
Can't run wires within X distance of water pipes
Can't run wires next to gas lines(don't recommend it)
No Wire Nuts in a Panel
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
The Following User Says Thank You to Saturday Cowboy For This Useful Post:
RST (02-04-2011)
Old 02-04-2011, 10:40 AM   #6
Rewards Points: 246
RST
No. It does not matter if its insulated or not.
The Following User Says Thank You to J. V. For This Useful Post:
RST (02-04-2011)
Old 02-04-2011, 10:50 AM   #7
RST
DIY Homeowner
Rewards Points: 150
ULEC! Funny!
Old 02-05-2011, 12:30 AM   #8
GRRRR I hate when people screw up and put wire nuts in a panel . Not that it is wrong just the fact that it looks like crap.
proremodel is offline   Reply With Quote
Old 02-05-2011, 06:33 AM   #9
Rewards Points: 506
What??
jlmran is offline   Reply With Quote
Old 02-05-2011, 10:33 AM   #10
Scared Electrician
agreed quilty
Old 02-05-2011, 10:34 AM   #11
Rewards Points: 246
Originally Posted by jlmran View Post
What??
Wire nuts and other connections can be made in panels. Panels can be used as raceways in most instances also.
Old 02-05-2011, 01:34 PM   #12
Rewards Points: 506
I know. I was questioning the 'anger'. Some folks really need help with priorities.
Old 02-05-2011, 02:23 PM   #13
Electrical Supplier
Rewards Points: 150
You can also remove the bussing and use it as a giant junction box provided you have a cover for it. This is common with fuse panels that get converted to breaker panels at the same amperage.
"Do it right the first time and avoid duplication of effort"
Your AHJ/Inspectors ALWAYS have the final say on ANY electrical code issue.
If in doubt, contact a licensed, experienced, reputable electrician to perform the work.
LyonsElecSupply is offline   Reply With Quote
Old 02-06-2011, 01:16 AM   #14
One of those quality control things. Don't start cutting your wire until you figured out you have enough to get to the bottom of the box.
Old 02-06-2011, 06:57 AM   #15
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Well yeah. For new work no kidding. What about a panel change?
You think it "looks like crap"?? Seriously? I'd MUCH rather see a few wire nuts in a panel (ABSOLUTELY LEGAL btw) than several splice boxes above it.
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Help needed on electrical question Partisan Electrical 9 02-25-2009 02:00 PM
electrical supply Darren Briggs Electrical 7 02-14-2009 04:46 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Furnace Electrical Supply.... caseywa HVAC 2 12-28-2006 10:37 AM
