Old 01-10-2013, 01:02 PM   #1
electrical wire gauge question
is it ok to branch off a light on a 20 amp circuit, and if so, must 12 gauge be used to the switch and light?
ahalbert is offline   Reply With Quote
Old 01-10-2013, 01:08 PM   #2
Licensed electrician
What does the circuit serve? Some circuits have restrictions on what they can serve.
Old 01-10-2013, 02:44 PM   #3
A "Handy Husband"
rjniles's Avatar
And if you are in Canada you can not put lighting on a 20 amp circuit.
Another reason to add your location; you get better answers.
Coastal South Carolina
rjniles is offline   Reply With Quote
Electrical loading question jimcorey Electrical 2 12-08-2012 08:27 AM
Hot Tub Wiring Question - Wire Type? AidanD55 Electrical 10 03-18-2012 01:16 AM
truck electrical question itin1200 Electrical 8 03-31-2011 02:58 PM
Real Basic Electrical question re: neutral wire hellothere123 Electrical 22 07-21-2009 07:07 PM
Electrical receptacle replacement question sherlock Electrical 7 05-20-2005 04:33 PM
