Electrical Wire Box Of Chandelier Is Getting Hot - Electrical - DIY Chatroom Home Improvement Forum
Old 07-09-2011, 03:14 PM   #1
electrical wire box of chandelier is getting hot
Hi,
I just installed my chandelier without any issue, but I noticed that the wire box is getting hot to the touch, even when the lights are off
Should I be concerned
Anne
paprika is offline   Reply With Quote
Old 07-09-2011, 08:12 PM   #2
dmxtothemax's Avatar
Rewards Points: 5,600
Where is the wire box mounted in relation to the light ?
Is it a metal wire box ?
Could the accumulated heat from the light be dissipated
by the box ?
Or is the box still hot /warm even if the light has not
been on for some considerable time ?
dmxtothemax is offline   Reply With Quote
Old 07-09-2011, 09:34 PM   #3
Licensed electrician
Rewards Points: 1,870
Is the box exposed to heat from an attic space above?
Old 07-09-2011, 10:29 PM   #4
Rewards Points: 1,016
Is the light the only thing powered by the wiring in the box?
____________
Vince
Blue 14-2 electrical wire corelo Electrical 5 12-02-2010 04:48 PM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 04:02 PM
Grounding a Hanging chandelier made for a electrical box Mount mjgumbo Electrical 6 03-21-2010 07:01 PM
Cap electrical wire? oscarMadison Electrical 5 03-01-2009 09:26 PM
Standard gauge for household electrical wire tripower Electrical 2 09-21-2008 11:42 PM
