Electrical Voltage - Electrical - DIY Chatroom Home Improvement Forum
Old 12-05-2010, 02:02 PM   #1
electrical voltage
I have only 95V at the light switch and only 7 volts at the light. It was working fine several days ago. I have 122V at the breaker. What could cause the voltage to have dropped?
katy14 is offline   Reply With Quote
Old 12-05-2010, 02:53 PM   #2
Rewards Points: 6,652
How are you measuring voltage? have you made any changes by replacing the light, or messing with the switch before this problem appeared?
The Following User Says Thank You to gregzoll For This Useful Post:
katy14 (12-05-2010)
Old 12-05-2010, 02:57 PM   #3
I changed out the switch about a month ago.
Old 12-05-2010, 02:59 PM   #4
Again, what are you using to measure the voltage? It is possible that you are seeing "Phantom" voltage at the light, is why you are seeing 7 volts. I would venture to guess that since you just recently replaced the switch, that something got messed up in that junction box, and needs to be double checked for loose connections.
Old 12-05-2010, 03:07 PM   #5
I am using a digital multi-meter to check the voltage.
Old 12-05-2010, 03:11 PM   #6
Then you are getting Phantom voltage. Go back and check the wiring at the light switch for loose connections.
Old 12-05-2010, 03:14 PM   #7
Connections are good and tight at the switch and i also checked the connection at the breaker. It is good also.
Old 12-05-2010, 03:21 PM   #8
Did you visually look at the connections at the switch, or actually take the connections apart at the wire nuts and switch, and reconnect? Go back and double check everything, even if you have to put another light switch on the light to make sure that you do not have a bad switch. Post a picture of the switch when you have done the above if it still does not work.
Old 12-05-2010, 03:23 PM   #9
joed's Avatar
Rewards Points: 11,998
Where are you measuring the voltage? What two points? Measure to neutral not to ground. Sounds like an open neutral and you are measuring to ground.
How to install new electrical box without attic access gilmores33 Electrical 10 02-14-2010 08:46 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 01:25 PM
high voltage fire alarm jungboklee Electrical 3 01-26-2009 10:07 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
