Electrical-using A 2 Pole Breaker For 120v Circuit - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 10-01-2011, 12:34 PM   #31
I=E/R
a7ecorsair's Avatar
Originally Posted by mreed View Post
One other thing, where they show the ac ground in the picture is where I have it grounded to earth. On the other side where the outputs, inputs etc. are is another bolt on the side of the inverter where we have always run the ground to the breaker.
It is hard for use to visualize what you have and terminolgy is sometimes a problem too. Like above, breakers don't have grounds but maybe the panel it is mounted in does.
You can leave the AC Ground connection at the inverter if you like but be sure your panel is also grounded and run your AC ground to the panel from the AC ground on the inverter.
a7ecorsair is offline   Reply With Quote
Old 10-01-2011, 06:43 PM   #32
Semi-Pro Electro-Geek
Rewards Points: 2,902
I can't visualize any of this. You don't run a ground wire to a breaker, and I doubt that you actually did. Pictures aren't hard. You just use the "manage attachments" button down below the reply window in the "additional options" section when you're typing a reply post.
mpoulton is offline   Reply With Quote
Old 10-03-2011, 03:58 PM   #33
I went from my breaker to a main panel box, bonded the neutral and ground and took the earth ground off of the inverter. Wah-la, everything is testing perfect! I am just putting the earth ground on the panel box, but I am happy to say that I have no more voltage between neutral and ground and everything inside and out is testing perfect. Thank you for all of your help!! I also moved my son's house to the main panel.
mreed is offline   Reply With Quote
Old 10-03-2011, 05:45 PM   #34
I=E/R
a7ecorsair's Avatar
Nice to hear it worked out
Main Circuit Breaker Question vladmir1111 Electrical 2 08-20-2011 09:15 PM
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 07:09 AM
900W and up trips breaker, Circuit draws power even with everything off... jasonblu Electrical 40 12-09-2009 03:29 PM
Old Electric Panel/ Circuit Breaker Box dankreboot Electrical 3 12-16-2008 01:52 PM
2 pole breaker Unregistered Electrical 3 09-11-2004 12:15 PM
