Electrical Timer Is Not Working - Electrical - DIY Chatroom Home Improvement Forum
Old 06-15-2012, 03:54 AM   #1
electrical timer is not working
how can i bypass the timer connect it directly.....red & white is in LOAD & one in LIVE & the other in NEUTRAL.....can I join all 4 wires? & operate it from the main switch
mwoks is offline   Reply With Quote
Old 06-15-2012, 04:00 AM   #2
Code05's Avatar
Rewards Points: 1,104
You need to retype your question and be more clear on what you are asking and then we can help.
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
mwoks (06-15-2012)
Old 06-15-2012, 04:04 AM   #3
how can i bypass the timer connect it directly. red & white is in LOAD & one in LIVE & the other in NEUTRAL. can I join all 4 wires? & operate it from the main switch
Old 06-15-2012, 04:07 AM   #4
hi Code05 is it clearer now?
Old 06-15-2012, 04:16 AM   #5
I have a small signboard which has florescent tubes & is operated by a timer. the timer is not working. i want to disconnect the timer & operate the signboard directly from the on/off switch. there are 4 wires inside the timer - red & white is in LOAD & one in LIVE & the other in NEUTRAL. can I join all 4 wires? & operate it from the main switch.
Old 06-15-2012, 05:04 AM   #6
Code05's Avatar
Yes, you can bypass the timer. No, do not connect all 4 wires together.
I assume this is 120 or 240 volts?
Old 06-15-2012, 09:09 AM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 2,108
A volt meter would help you confirm what the voltage of each wire is....and hence how it should be connected.
Old 06-16-2012, 01:36 AM   #8
it is 240 Volts
GE Sunsmart Digital Timer Installation dtn311 Electrical 1 08-01-2011 01:16 AM
Maytag IntelliDry pye/4500 Dryer not working 57_Hemi Electrical 2 11-19-2010 09:28 PM
timer requires a 40 watt min. load, I only have 10...now what? glassbird Electrical 3 08-18-2010 11:32 AM
Mechanical timer wiring? Duane 70 Electrical 5 06-16-2010 08:57 PM
What gloves to wear when working with electrical? twilightcall Electrical 7 01-04-2008 05:34 PM
