-   -   electrical timer is not working (http://www.diychatroom.com/f18/electrical-timer-not-working-147092/)
mwoks 06-15-2012 03:54 AM
how can i bypass the timer connect it directly.....red & white is in LOAD & one in LIVE & the other in NEUTRAL.....can I join all 4 wires? & operate it from the main switch
Code05 06-15-2012 04:00 AM
You need to retype your question and be more clear on what you are asking and then we can help.
mwoks 06-15-2012 04:04 AM
how can i bypass the timer connect it directly. red & white is in LOAD & one in LIVE & the other in NEUTRAL. can I join all 4 wires? & operate it from the main switch
mwoks 06-15-2012 04:07 AM
hi Code05 is it clearer now?
mwoks 06-15-2012 04:16 AM
I have a small signboard which has florescent tubes & is operated by a timer. the timer is not working. i want to disconnect the timer & operate the signboard directly from the on/off switch. there are 4 wires inside the timer - red & white is in LOAD & one in LIVE & the other in NEUTRAL. can I join all 4 wires? & operate it from the main switch.
Code05 06-15-2012 05:04 AM
Yes, you can bypass the timer. No, do not connect all 4 wires together.
I assume this is 120 or 240 volts?
ddawg16 06-15-2012 09:09 AM
A volt meter would help you confirm what the voltage of each wire is....and hence how it should be connected.
mwoks 06-16-2012 01:36 AM
it is 240 Volts
