Electrical Tape Inside Panel? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-10-2013, 09:56 AM   #1
Trucon01's Avatar
Rewards Points: 510
Electrical Tape inside panel?
Hi All,
While looking at my newly installed panel, I noticed that my dryer line (10-3, 30A) has slices on the conductor insulation, both on the black and red. I'm guessing this is because the electrician used a box cutter to strip the sheathing and hit the conductor lines.
Am I allowed, by code, to electrical tape the small sections on each wire inside the panel? We are on the 2008 NEC.
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 01-10-2013, 10:22 AM   #2
Rewards Points: 204
Yes. And it would be a good idea. I would contact your electrician and ask him to come back and do it at no charge. If its new wire you know he did it. If its old wire he should have fixed it.
Shrink tube is the best way to repair this. But you will have to remove the wires from their terminals to do it.
The Following User Says Thank You to J. V. For This Useful Post:
PaliBob (01-11-2013)
Old 01-10-2013, 11:25 AM   #3
Trucon01's Avatar
Rewards Points: 510
Thanks JV. Yes this was a whole new run. It was a 3 wire aluminum wire before, now its a 4 wire 10-3 copper.
I can fix this myself, I'm not worried about him coming back.
Thanks for the response!!
The Following User Says Thank You to Trucon01 For This Useful Post:
J. V. (01-11-2013)
Old 01-11-2013, 07:50 AM   #4
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Originally Posted by Trucon01 View Post
Hi All,
Yes, you can tape the conductors. Electrical tape is 600V rated.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
existing electrical panel in clothes closet Ranger2001 Electrical 7 07-26-2012 09:45 AM
Electrical conduit coming through foundation leaking inside Madmike7221 Electrical 2 05-09-2012 07:52 AM
new sub panel BlueBSH Electrical 11 01-22-2012 08:28 AM
100 -> 200 amp panel upgrade questions philipjcaputo Electrical 1 10-30-2009 03:35 AM
Electrical Panel "cut-in" question Todd-sta Electrical 52 12-03-2008 11:07 PM
