Old 07-06-2012, 01:55 PM   #1
Electrical switches needed replaced
I needed to replace some old switches for the disposal and the "over the sink" light that were from the 70's. They were configured differently than the new switches that I purchased. I also noticed that the old switches were not grounded. I ended up pulling it all out and hope to do it correctly. Previously all the white wire was conected together welded and taped, then the hot black was run with a section cut out of the center that was then strung to the next switch. I don't think that was correct either. Any help doing this correct is greatly appreciated.
ColdYeti is offline   Reply With Quote
Old 07-06-2012, 02:13 PM   #2
joed's Avatar
Do It like it was before. It was fine.
or
Connect all the whites together with a wire nut.
Connect all the grounds together and to the switches.
Connect the power black to two short black pigtails with a wire nut.
Connect one pigtail to each new switch.
Connect the black from the light and GD to the switches.
Do not PM with questions that can be asked in a forum. I will not respond.
The Following User Says Thank You to joed For This Useful Post:
bob22 (07-07-2012)
Help needed: replacing bathroom fan/light & switches. bkboggy Electrical 12 12-28-2011 11:07 PM
Electrical Panel Upgraded... any additional work needed? Thadius856 Electrical 5 08-06-2011 05:27 PM
Just bought a 1946 house, redoing kitchen, what electrical fixes/upgrades needed? TomServo Electrical 18 09-21-2009 07:48 AM
Replaced outlets, now wall switches don't work? PittsburghPaul Electrical 3 08-09-2009 06:50 PM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 12:12 PM
