Old 11-04-2010, 08:20 PM   #1
Electrical switch 3 wires
Need Help. I had a dimmer on a kitchen light. I replaced the overhead light with a new fixture with the help of an electrician family member. Was told by the family member that I needed to replace the dimmer switch. When I removed the dimmer there was 3 wires in the switch. That is 3 black 3 white and 3 ground. How do I wire this switch to get power to the outlet and to the basement switch.
eganrut is offline   Reply With Quote
Old 11-04-2010, 09:09 PM   #2
joed's Avatar
How were the wires connected together? There was probably only two of those wires connected to the dimmer. Those two wires connect to your new switch.
Do not PM with questions that can be asked in a forum. I will not respond.
electrical plug and switch Linda Patterson Electrical 3 05-10-2010 07:55 PM
Help with four way switch jwetsit Electrical 3 05-04-2010 07:05 AM
Bedrooms have no ceiling light, light switch controls one electrical outlet? notenoughtime Electrical 16 05-25-2009 01:09 AM
Electrical Question - adding a 3 way switch to existing Light Marcus23 Electrical 5 10-11-2008 09:52 AM
3-Way Switch Wiring MrBill_DIY Electrical 8 09-07-2008 06:53 PM
