#1 |
electrical supply
Would it be ok to disconnect the cable from an immersion heater in a hot water tank and connect it to an electric radiator in the bathroom?
#2 |
electrical supply
Why would you want to?
Why do you have to replace the radiator cord? If it is burnt you may have other problems! Gary |
#3 |
electrical supply
I need to install an electrical feed to the bathroom. I don't use the immersion heater and would like to install a new electric radiator. I thought that as the immersion heater cable is high wattage plus it already has a timer attached i would just disconnect it and feed it through the bathroom.
#4 | |
electrical supplyQuote:
#5 |
electrical supply
If it is to supply power to the bathroom. I think i would do it right and install the proper size circuit with a GFI.
Gary |
#6 |
electrical supply
If you said you wanted to disconnect your hot water heater and use the circuit instead for your heater, I would say OK, but what voltage, wire size and amperage breaker does the water heater circuit have - and this circuit is of course only used for the hot water heater currently. Correct?
So the hot water heater would be *totally* disconnected! Then the next question is what voltage and wattage is the heater? And what size circuit breaker does the manufacturer recommend (if they do)? Is this a hard wired heater or plug in? If plug in, what type plug? If on the other hand you wanted to leave part of the hot water heater connected and run a wire from the hot water heater to the new heater, I would say this is not a good idea. |
#7 | |
If voltage and amperage are the same on both units, sure. If not, some adjustments must be made. |
| Display Modes | |
| hooking up dryer....bronx ny code | SURFBUG | Appliances | 6 | 10-14-2008 10:41 PM |
| Galvenized supply to PEX, How to make connection? | twilightcall | Plumbing | 4 | 07-28-2008 10:28 PM |
| Electrical Box near Shower Valve | dasajame | Electrical | 3 | 07-07-2008 07:46 AM |
| 2 Prong Electrical | mjcongleton | Electrical | 10 | 04-16-2008 09:59 AM |
| Furnace Electrical Supply.... | caseywa | HVAC | 2 | 12-28-2006 11:37 AM |
