Electrical Subpanel - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-09-2012, 07:09 AM   #16
Master Electrician
I still don't get why your putting in a subpanel. I'm also pretty sure the minimum size feeder conductor for a panel is #10. Your installing a multiwire branch circuit and no panel or ground plate or anything else is needed. You take a 12/3(allows for distance) to your outbuilding. You go to a junction box. You take the black and a white to one gfci. You take a red and a white to the other gfci. You wirenut the reds together at the junction box. You wirenut the blacks together at the junction box. You wirenut the whites together at the junction box. Job finished.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 08-09-2012, 07:12 AM   #17
Master Electrician
It's been said three times at least that you DO NOT connect the neutral and ground at a subpanel, the p.s knight book is wrong as proven by the actual code I posted.. My honest opinion is that you may be in over your head on this one. Do some research and learn your stuff a bit then give it a go .
Schedule 40 PVC in Chicago? franwalker Electrical 56 12-20-2011 10:04 PM
Fixing multiple attic electrical issues before blowing in insulation darlingm Electrical 11 11-19-2011 09:19 AM
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 02:23 PM
Wiring a sub panel to another sub panel Uncle Wayne Electrical 25 02-08-2011 09:50 AM
Subpanel Questions/Running electrical to garage. FlyGuy Electrical 28 05-24-2008 10:50 PM
