Electrical Sub Panel Grounding - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-17-2011, 07:18 PM   #16
This is a 1960 addition built on a 1947 house. I have three #6 wires in a greenfield feeding a subpanel, a black, a red and a white. Is this alone proper grounding? Everything in the sub panel is BX.
KellyElaine is offline   Reply With Quote
Old 01-17-2011, 07:34 PM   #17
I just went to the panel, I may have been incorrect, it could be 6-3 BX wire in the panel.
Old 01-17-2011, 07:46 PM   #18
iminaquagmire's Avatar
Rewards Points: 338
If you have 6-3 then you're all good for a new panel. Like I said before, just make sure you keep the neutral unbonded from the panel case and use a separate bar for the grounds.
If you really have flexible metal conduit and no separate ground, you must refeed the subpanel with 4 wires ( 2 phase conductors, a neutral, and a ground). The above mentioned bonding rules apply here too.
iminaquagmire is offline   Reply With Quote
Sub panel wiring & grounding kwcamaro Electrical 1 03-06-2010 08:58 AM
grounding of main panel and sub panel in older house linkysys Electrical 2 10-01-2009 05:34 PM
new Main Panel Grounding lrr81765 Electrical 8 10-09-2008 12:16 PM
advice on installing equipment grounding bar in main panel pacifier1er Electrical 5 05-29-2007 06:55 PM
