Old 04-27-2008, 09:34 AM   #1
Electrical storm - outlets not working
We had an electrical storm a couple days ago where the power was out for a little while. When it came back on, 4 of the outlets in our kitchen no longer work. I looked at the box in the basement, and nothing has been tripped. What should be the next step? I don't want to replace the outlets if it's probably something else that's been damaged. Yet, I don't want to call an electrician if it's something really simple that I just overlooked. Thanks.
SG94 is offline   Reply With Quote
Old 04-27-2008, 09:56 AM   #2
Licensed Pro
Look for a tripped GFCI somewhere in the kitchen. There is a good chance that the GFCI may also be damaged and need replacing if you received a close proximity lightning strike.
Old 04-27-2008, 10:02 AM   #3
What do you mean "somewhere in the kitchen?" None of the switches were tripped in the electrical box. There are two labeled "kitchen outlets", and I moved them off and back on, but nothing changed. Should I look somewhere else? Thanks again.
Old 04-27-2008, 10:20 AM   #4
Licensed Pro
A GFCI receptacle has two buttons, one labeled "test" and one labeled "reset". There should be two in the kitchen somewhere along the countertop, although if it is an older house, there may only be one and it may be somewhere else in the kitchen. When you find it, try pressing the "reset" button and see if power is restored.
Old 04-27-2008, 10:28 AM   #5
You ROCK!! Thank you so much. That outlet was covered by a surge protector since I use it to plug in our cordless phone and previously my wireless router. When I removed it, I found the reset switch. (forgot it was there) Thanks again!
Loose electrical outlets travishume Electrical 30 08-01-2008 08:21 PM
What gloves to wear when working with electrical? twilightcall Electrical 7 01-04-2008 06:34 PM
Electrical outlets and Granite backsplash, how? section8 Remodeling 6 01-08-2007 07:55 AM
Can a diyer install electrical outlets? yummy mummy Building & Construction 12 12-23-2006 07:54 PM
Electrical outlets and Granite backsplash, how? section8 Electrical 10 07-01-2006 09:53 AM
