Electrical Split In Bathroom? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-22-2011, 09:29 AM   #1
Question
Electrical split in bathroom?
I am renovating my 2nd floor bathroom...I had an electrician come in to run new wiring. As he was pulling wire thru the chase (basement to second floor) the wire pulled off his feeder and he only got about 2 feet out of chase. He tried pulling but but no luck...wire was stuck in chase. He decided to put in a junction box...6" above floor behind toilet and 6" from tub....his plan was to cover box with a blank plate and splice wire from junction box to new sconces. I told him that this was unacceptable and that I wanted a homerun from basement to the sconces even if these means opening chase on lower level bathroom.
I had three reasons (1) I have two young children and I was afraid of water that close to coved junction box and (2) I am doing a complete gut of my bathroom and it's ugly and (3) I plan on selling this how and I don't want to have to fix in the case an inspector doesn't agree with his solution. Did I do the right thing?
Bill
wjmtemple is offline   Reply With Quote
Old 11-22-2011, 09:47 AM   #2
Licensed electrician
Rewards Points: 1,892
Water should not be an issue unless the bathroom is flooded, in which case you have other issues.
An accessible junction covered with a blank plate is code compliant.
Old 11-22-2011, 10:38 AM   #3
Rewards Points: 6,652
My question is, where was the helper watching the pull, so that it did not snag.
Old 11-22-2011, 05:07 PM   #4
A junction box behind the toilet? Ugh! Compliant yes but I wouldn't have that in my bathroom. I'd call for a do-over.
kwilcox is offline   Reply With Quote
Old 11-22-2011, 05:13 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 654
Your house, your money, as long as it is code compliant, you get what you asked for.
It is code compliant and not an issue, but you don't want it there, he needs to fix it.
jbfan is online now   Reply With Quote
HRV With Bathroom Stale Air Pickup??? 1BadBoy Building & Construction 10 06-17-2011 02:17 PM
Wondering if it makes economic sence to replace a bathroom exhaust fan ChrisJJ HVAC 0 06-14-2011 10:36 AM
worth it in terms of energy savings to replace bathroom exhaust fans? ChrisJJ Electrical 0 06-14-2011 10:17 AM
How much distance should the vanity top and the electrical outlet in the bathroom? Tobeyone Electrical 2 02-03-2010 11:12 AM
Bathroom electrical outlets dontom Electrical 2 01-07-2009 08:11 AM
