Originally Posted by fblankinship
While building a sun room addition on my modular house I discovered some questionable wiring in the wall. When I removed the siding from the existing house so I could wire in the new addition I noticed electrical splices that were covered up. These splices were in boxes. MY QUESTION: Does the code allow splices that are hidden and not accessible? I didn't think so but maybe. If not allowed I could rewire them into a receptacle box I will install, Is it ok to have 2 different circuits running through one box?
I know some Mobile home and Moduar homes they did use the AMP or TYCO splice kits and it is legit for this purpose but just plain jane wirenuts without juction box then no it is not legit.
{ A side note I am not too crazy with them due I have few failures so end up put a junction box and resplice with proper items }
If you want to mount the junction box then yes you can but do not buried behind the drywall or other means and yes it is fine to run with two diffrent circuits in the junction box keep the netural seprated but the ground { bare or green conductor } can tie together without issue.
Merci.
Marc
