Electrical Socket Help! - Electrical - DIY Chatroom Home Improvement Forum
Old 01-26-2010, 11:22 AM   #1
Hey I have a problem with the outlets in the second story of my town house. This morning I turned on my space heater and blew a fuse, or so I thought. I went to flip the breakers back on, and they were already on. I flipped them on and off, as well as the breakers for the lights on the second floor, however the outlets are still not working. Here's the other thing- only the top socket in each outlet is not working. The bottom ones are fine. The electrical maintenance fellow tried to explain to me that the top outlets are attached to the light switch, but I know for a fact that they are not. So he was no help.
Now I know this is probably a pretty basic fix, however as a college kid thats living in his own house for the first time with a bunch of clueless roommates I have no idea what to do, other than what I've done (flipping the breakers back on or off and on), and am just generally not that handy. Could someone offer me a solution?!
Thanks in advance!
SMBbone is offline   Reply With Quote
Old 01-26-2010, 11:24 AM   #2
Also, this is not the first time this happened. About a month ago the same thing happened and a different guy came and fixed it really easily.
Old 01-26-2010, 11:29 AM   #3
Top outlets are either controlled by a switch or wired thru the switch & you have a bad connection
Or
A 2nd breaker controls the top part of the outlets & needs to be reset
or there is a GFCI somewhere that tripped
Old 01-26-2010, 11:44 AM   #4
I reset all the GFCI's and the breakers but nothing worked. As for the plugs being connected to the light switch, is it possible to have such a bad connection that the sockets work all the time? The outlets seemed to be completely independent in my room as well as my roommates rooms and now we're all experiencing the same problem... is it possible the fuse actually needs to be replaced?
Old 01-26-2010, 11:52 AM   #5
Just call me Andrew
Rewards Points: 1,020
Can you pull one of the non-working outlets out of the wall and see how many wires are connected (and the colors).
You may want to turn the main breaker off before messing with this since you aren't sure which breakers control each half of the outlet.
Andrew
secutanudu is offline   Reply With Quote
Tags
blown fuse , circuit , circuit breaker , electrical , outlets
Electrical socket question hayzen Electrical 2 01-15-2010 03:16 PM
Electrical Engineer allowed to do Electrical work? SarahJennifer Electrical 48 09-21-2009 09:15 PM
Slight electrical current in bathroom faucet water + other unusual electrical events story Electrical 9 09-16-2009 11:28 PM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 12:12 PM
2 Prong Electrical mjcongleton Electrical 10 04-16-2008 09:59 AM
