Electrical Socket - Electrical - DIY Chatroom Home Improvement Forum
Old 03-20-2013, 07:55 PM   #1
electrical socket
Got a bad socket in bathroom changed the socket reset breakers still no power. The socket is hot the small jolt I got messing around with it says so. I'm at a loss. Help.
andrew20101 is offline   Reply With Quote
Old 03-20-2013, 08:10 PM   #2
Rewards Points: 1,440
There may be a loose neutral connection. That loose connection could be at another socket (receptacle) or in a switch box on the way (on a daisy chain) back to the breaker panel.
If the neutral has a loose connection, you can still get a shock if you touch both the hot wire or terminal and a grounded object.
Old 03-21-2013, 07:34 AM   #3
Rewards Points: 2,516
I use sockets for securing/unsecuring nuts & bolts. How did you get shocked by a socket?
But follow Allans advice. That is most likely your issue.
hammerlane is offline   Reply With Quote
Best way to cover up old ceiling electrical socket? ohman Electrical 1 11-13-2012 08:04 PM
Installing OTR microwave but no electrical outlet in upper cabinet salilsurendran Electrical 62 09-21-2012 09:51 PM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 07:46 AM
Electrical Socket Help! SMBbone Electrical 4 01-26-2010 11:52 AM
