-   -   electrical socket (http://www.diychatroom.com/f18/electrical-socket-175071/)
andrew20101 03-20-2013 06:55 PM
electrical socket
Got a bad socket in bathroom changed the socket reset breakers still no power. The socket is hot the small jolt I got messing around with it says so. I'm at a loss. Help.
AllanJ 03-20-2013 07:10 PM
There may be a loose neutral connection. That loose connection could be at another socket (receptacle) or in a switch box on the way (on a daisy chain) back to the breaker panel.
If the neutral has a loose connection, you can still get a shock if you touch both the hot wire or terminal and a grounded object.
hammerlane 03-21-2013 06:34 AM
1 Attachment(s)
I use sockets for securing/unsecuring nuts & bolts. How did you get shocked by a socket?:laughing::laughing:
But follow Allans advice. That is most likely your issue.
