Old 03-03-2013, 07:55 PM   #1
Electrical Shut off but breaker did not trip
I have a situation where I have lost power on a large circuit but the breaker did not trip. What could be causing this? Please help.
Katerynuk is offline   Reply With Quote
Old 03-03-2013, 08:07 PM   #2
Electrical Contractor
The breaker trips to the mid position, so to reset you turn it off then back on again.
What do you mean large circuit?
You could also have a loose or broken connection somewhere in the circuit.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 03-03-2013, 08:07 PM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Open hot wire or open neutral .... how about giving us a tad more information ....
What does this circuit control .. lights and receptacles or other ?
Also do what jbfan suggested
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 03-03-2013, 08:08 PM   #4
Not even close to enough info.
What circut?
What would have caused it to trip?
How many amps?
Old 03-03-2013, 08:09 PM   #5
Something keeps tripping the ground. Trying to figure it out. Multiple recepticles on one circuit.
Old 03-03-2013, 08:11 PM   #6
Nothing trips the ground!
A little more detail will help.
Old 03-03-2013, 08:19 PM   #7
Found it. Found a loose white wire at a recepticle. Up and running again. Thanks guys.
The Following User Says Thank You to Katerynuk For This Useful Post:
jbfan (03-03-2013)
Circuit breaker wont trip? adgjqetuo Electrical 2 02-17-2013 10:50 PM
Electrical Main Breaker Flips Dougie Down Electrical 27 01-13-2013 10:23 PM
bad outlet --doesn't trip breaker lynnralphie Electrical 2 11-15-2012 01:19 PM
Drilled through 12/3 and breaker didn't trip vseven Electrical 12 04-11-2010 12:03 PM
Will reverse polarity trip breaker?? Duane 70 Electrical 60 12-05-2008 11:18 PM
