Electrical Service To Rotary Lift - Electrical - DIY Chatroom Home Improvement Forum
Old 06-10-2009, 06:41 PM   #1
electrical service to Rotary lift
need some help here, ive got a Rotary lift im running electrical service to, the motors name plate says....;
2 hp
1.5 kw
17-16 amps
208-230 vt
60 hz
1700 RPM
IP 54
duty INT
the run is about 60 feet
im thinking 10/2 220 20 amp breaker..... please give me some advice
december45 is offline   Reply With Quote
Old 06-10-2009, 07:35 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
What is a rotary lift? Where is it located?
Old 06-10-2009, 08:58 PM   #3
It's a brand of automotive lift. The voltage seems like a 3 phase? I have never hooked one up yet so can't say for sure. I do however remember when I use to work at a dealership our lifts were three phase. Ben
swaterbenny is offline   Reply With Quote
Old 06-10-2009, 09:36 PM   #4
Ah. I see. Thank you.
12/2 is all you need if the panel is relatively close.
Old 06-10-2009, 10:32 PM   #5
it is single phase
Old 06-11-2009, 11:14 AM   #6
Rewards Points: 246
12/2 on a 20 amp single pole breaker.
Old 06-11-2009, 04:03 PM   #7
It's 230v J.V.
Old 06-11-2009, 06:37 PM   #8
Idiot Emeritus
Rewards Points: 1,492
#12 wire is fine, I wouldn't use #10. 12 is much easier to work with.
A 20 amp breaker will likely work, but if it trips on starting a 30 is the maximum allowed by code. This is one of the few times it's legal to use a 30 with #12s, and only if the motor is hard-wired. No cord-and-plug.
Rob
micromind is offline   Reply With Quote
Old 06-12-2009, 12:47 AM   #9
" Euro " electrician
frenchelectrican's Avatar
#12gauge {4.0mm˛} will work just fine with this useage and you will need 20A double pole breaker*
* if kick out the breaker during start up go with either 25 or 30 amp breaker { note this is allowed per art 430 only with hard wired motour hook up.}
Merci,Marc
Need info on pricing electrical service... sotoremodelers Electrical 3 01-05-2009 10:37 PM
electrical service for new house ehurlbut Electrical 4 08-20-2008 08:14 PM
no disconnecting means at the electrical service entrance Denhamjw Electrical 34 06-30-2008 07:36 AM
Electrical service too near valley of roof? adamselene Roofing/Siding 3 05-11-2007 07:56 AM
electrical service to barn bsteven Electrical 1 04-18-2005 08:43 PM
