#1 |
Electrical Service Required for an Electric furnace
Hello. I'm thinking about installing an electric furnace in my home. I currently have a 100Amp service. I know that it's common to install a 200 amp panel when a home has an electric furnace. Is this code? Can a home run ok w/ a 100 amp panel and an electric furnace? In missouri.
thanks |
#2 |
Moderator
The size of the panel and the main overcurrent device doesn't really have a heck of a lot to do with whether or not the furnace is electric. The service is sized based on the service demands of the home as a whole. That is often a "rule of thumb" thing but service calcs are the only way to know for sure. Think of it this way...If you have a 100amp service, what are the odds that you'll ever be drawing 100amps? Not likely in most cases.
There's not a requirement that says you've got to have a 200 amp service just because you've got an electric furnace and/or water heater. If a service person says that's the case, ask them to walk you through their service calcs. (just my opinion, but you'll hate the electric furnace if you've currently got a gas unit) |
#3 | |
Electrical Service Required for an Electric furnaceQuote:
#4 |
This project is for a rental home. After spending the better part of friday niht and saturday repairing a gas leak and then having the gas company fail me for the furnace flue... and then repairing it, I'm leaning towards making the home all electric for reliability. I believe the cost is a little higher, but to never have gas / exhaust issues is a major plus.
Just out of curiosity, what sort of amp draw would an electric furnace pull (in a 950 s.f. home? |
#5 |
Xtreme DIY'r
You are doing your own work on a rental property?
Are you licensed ? Everything I have heard everywhere states only a Pro can do work on rental properties ? |
#6 |
Scuba:
Huh? I must be overlooking your sarcasm. |
#7 |
Xtreme DIY'r
Electrical Service Required for an Electric furnace |
#8 |
ScuabaDave
Gosh. You caught me. I wasn't trying to be deceptive. Did I ever say that I personally was going to install the unit myself? NO. I DID NOT. Why are you such a worry wart? IF I had the proper training and licensing, there would be nothing wrong with me doing the work anywhere. According to what you're saying, as a landlord, I can't even paint huh? Don't send me to jail. Why should it matter whether I preface my question with "on a rental property" I'm a diyer like you. Since my work is often on rental homes, does it make it not worthy or interesting to discuss? I think not. |
#9 | |
Xtreme DIY'r
![]() Again, many areas you are not allowed to do this type of work on property you are renting out Its a matter of wether you are legally able to do the work Threads that discuss illegal work ARE CLOSED I also suggest that you check your attitude |
| Display Modes | |
| Here is tip to service a furnace. | Tator1076 | HVAC | 0 | 12-27-2009 09:51 AM |
| Electric Furnace question | whatsthis | HVAC | 32 | 04-08-2009 08:39 AM |
| furnace or electrical help | tuasoi | Electrical | 13 | 11-29-2007 01:53 PM |
| electric furnace need help | Unregistered | HVAC | 3 | 10-16-2007 03:41 AM |
| electrical service to barn | bsteven | Electrical | 1 | 04-18-2005 09:43 PM |
