Electrical Service For New House - Electrical - DIY Chatroom Home Improvement Forum
Old 08-19-2008, 08:16 PM   #1
electrical service for new house
Hi,
I am running a new service into my house from the meter base. I had a roll of URD 4-4-2 triplex wire that i was going to use to run into my house from the disconnect on the outside of my house. I was told by a friend that URD is not approved to enter a structure from the meter or the service disconnect. I was wondering if this is true and what wire i will need to run to my load center from the disconnect.
I found from one search that i might be possible to run the urd in conduit from the meter to the disconnect and then from there to the load center, but im unsure. Anyone have some advice? It would be greatly appreciated!
ehurlbut is offline   Reply With Quote
Old 08-20-2008, 11:56 AM   #2
Registered User
Termite's Avatar
Type URD (underground rural distribution)/USE (underground service entrance) cables cannot be used inside a structure, even if in a raceway. Their jacket is not flame-retardant. NEC article 338.10A.
Are you sure what you have is URD or USE cable? Type RHH and RHW have different jackets that would allow their use in a raceway in a structure.
Old 08-20-2008, 08:12 PM   #3
yes it is URD. i got the roll from a friend who got it at home depot for a project he was doing and had some left over. its 200A aluminum triplex. Can i use this cable to go from the meter to my main on the outside of the house, then use something different from there, to my breaker panel?
Old 08-20-2008, 09:13 PM   #4
Registered User
Termite's Avatar
Can't use it indoors.
Old 08-20-2008, 09:14 PM   #5
Electrician
If it stays outside its fine, but it cannot enter the structure.
chris75 is offline   Reply With Quote
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
electrical service for garage rocketman Electrical 1 12-01-2006 06:13 PM
Will my house make my kids sick??? jokrupinski General DIY Discussions 18 09-29-2006 05:05 AM
electrical service to barn bsteven Electrical 1 04-18-2005 09:43 PM
