electrical service line
Once the "service" line enters the house, it requires overcurrent protection and a disconnecting means.
IF you have an outside disconnect, then the line can run just about anywhere -- through the attic, in a basement, or underneath in a crawl space.
If there is no outside disconnect, then you should not have more than a few feet of line inside of the structure. One exception is your lines installed in a conduit encased in not less than 2" of concrete, creating a core duct.
-KB
Life is uncertain -- eat dessert first!! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
