Electrical Service To Guest House - Electrical - DIY Chatroom Home Improvement Forum
Old 12-25-2010, 09:59 AM   #1
Electrical Service to Guest House
The 3 wire service to the guest house runs through a meter....then a 100 amp disconnect. Through some underground conduit...up the outside wall....into the attic(No conduit).....then into a 100amp panel. It has a 100 amp main breaker. There is a ground rod. My question is this...should the ground and neutral be linked together?
CM
cmlewis is offline   Reply With Quote
Old 12-25-2010, 10:21 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,878
How old is the installation?
What wires were run between the buildings?
Where are you located?
Speedy Petey is online now   Reply With Quote
Old 12-25-2010, 01:29 PM   #3
I=E/R
a7ecorsair's Avatar
Some information that will help:
You said there is a ground rod; where is the large ground wire currently connected - in the outdoor 100 amp disconnect?
How many wires run between the outside disconnect and the main panel. Are the wires individual or are they in a sheath?
a7ecorsair is offline   Reply With Quote
Need Help - House Electrical Issue nottimtaylor Electrical 2 10-19-2010 09:10 AM
200 Amp service really needed for a 830 sq ft house? overkill? alexz Electrical 7 11-16-2009 06:54 PM
Just bought a 1946 house, redoing kitchen, what electrical fixes/upgrades needed? TomServo Electrical 18 09-21-2009 07:48 AM
How Bad Does This Electrical System Look??? (buying a house) Mr_Pat Electrical 33 08-31-2009 09:33 PM
electrical service to barn bsteven Electrical 1 04-18-2005 09:43 PM
