-   -   Electrical Service to Guest House (http://www.diychatroom.com/f18/electrical-service-guest-house-90408/)
cmlewis 12-25-2010 08:59 AM
The 3 wire service to the guest house runs through a meter....then a 100 amp disconnect. Through some underground conduit...up the outside wall....into the attic(No conduit).....then into a 100amp panel. It has a 100 amp main breaker. There is a ground rod. My question is this...should the ground and neutral be linked together?
CM
Speedy Petey 12-25-2010 09:21 AM
How old is the installation?
What wires were run between the buildings?
Where are you located?
a7ecorsair 12-25-2010 12:29 PM
Some information that will help:
You said there is a ground rod; where is the large ground wire currently connected - in the outdoor 100 amp disconnect?
How many wires run between the outside disconnect and the main panel. Are the wires individual or are they in a sheath?
