Electrical Service For Garage - Electrical - DIY Chatroom Home Improvement Forum
Old 12-01-2006, 04:37 PM   #1
electrical service for garage
guys im tryin to put electric in a steel bldg. problem is that i want a wholenew service but the riser is on the other end of the house 1st question :can i put a new meter riser and disconnect on that side of the house and then run thru a crawl space in pvc to the side where the bldg is . then run under ground to the bldg in 1and 1/2 pvc. 2nd question: do i have to put in any lightning protection? any anwsers to these would be great .
rocketman is offline   Reply With Quote
Old 12-01-2006, 06:13 PM   #2
joed's Avatar
Rewards Points: 12,002
Where you put the riser and meter will need to be approved by the power company. If there is no disconnect in the meter base you will not be allowed to run the cable through the crawl space. The part of the cable before the main breaker/disconnect must be the shortest possible INSIDE the house. That usually means about 5-10 feet at most will be allowed.
Removing Outdoor Electrical Service scchang Electrical 5 08-15-2007 12:24 PM
200 amp panel with a 100 amp service? alexz Electrical 10 07-29-2007 11:00 PM
Electrical service too near valley of roof? adamselene Roofing/Siding 3 05-11-2007 08:56 AM
Suspected open/loose service neutral mrtomwj Electrical 5 09-28-2006 09:46 AM
electrical service to barn bsteven Electrical 1 04-18-2005 09:43 PM
