Electrical Service - Electrical - DIY Chatroom Home Improvement Forum
Old 08-04-2011, 11:28 PM   #1
electrical service
i have just erected a 40ft x 30ft red iron workshop and i want to run service to it from house.distance from house to workshop is about 200ft going to have various recepticals and shop tool s.need some ideas what i might for serive thanks jim
jimdal12 is offline   Reply With Quote
Old 08-05-2011, 07:08 AM   #2
Wow, with that much space I could install one of every tool made(almost). Without specifying what you will install, I would guess a 100A panel is in order. That would allow for a lot of heavy duty equipment, including welders. And you could run them on 240. If you go smaller and need more, it is harder to make changes.
Old 08-05-2011, 09:05 AM   #3
Licensed electrician
Rewards Points: 1,010
Depending on the shop power requirements you may be looking at a service upgrade on the house.
The best way would be a demand load calculation for both the shop and house.
underground Electrical service Ben-Iesau Electrical 0 11-26-2010 03:08 PM
Do I need to upgrade my electrical service? bandtank Electrical 6 02-11-2010 11:27 PM
Electrical Service Required for an Electric furnace brokenhammer Electrical 8 01-11-2010 12:02 PM
Remodel - Moving from 200 amp service to 320 amps stevedar Electrical 20 11-29-2009 09:14 PM
electrical service to barn bsteven Electrical 1 04-18-2005 09:43 PM
