Old 05-17-2011, 10:40 PM   #1
Electrical Receptacle Questions
Ok... I pulled this outlet out to take a look. The receptacle is switched and the switch has one cable coming back to it, so this would be a power-receptacle-switch situation. I'm just a bit confused by the neutral wires coming in to the receptacle and nothing labeled "hot" at the switch.
Electrical Receptacle Questions-image-2025560266.jpg   Electrical Receptacle Questions-image-1496934003.jpg   Electrical Receptacle Questions-image-803918692.jpg
Shaotzu is offline   Reply With Quote
Old 05-17-2011, 10:43 PM   #2
Licensed electrician
What you have is a switch loop to the switch on the black/white splice and a fully switched receptacle.
The black in the splice is power in and feeds power to the switch on the white.
Old 05-17-2011, 11:25 PM   #3
Ok ... Thanks for the info. However, still confused on which wire actually is power in...
Old 05-17-2011, 11:28 PM   #4
Electrical Contractor
The power in will be one of the black wires connected to the white wire feeding the switch.
The other black wire will take the power to the next device.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 05-18-2011, 12:03 AM   #5
So the black coming out of the receptacle is to the switch?
Old 05-18-2011, 12:07 AM   #6
Scared Electrician
Saturday Cowboy's Avatar
that would be correct
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Replacing receptacle with GFCI wiring problem braden Electrical 8 04-06-2011 09:32 AM
5th wheel electrical receptacle House2488 Electrical 8 08-30-2010 02:22 AM
Post mounted electrical receptacle ¯¯NI¯l¯RO¯¯ Electrical 13 04-19-2010 03:20 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
DIY electrical work questions for finishing a basement. mac41099 Electrical 7 11-16-2007 08:59 PM
