Electrical Range Installation - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-29-2013, 07:44 PM   #16
Electrical Contractor
jbfan's Avatar
Rewards Points: 400
Originally Posted by electricianadv View Post
Thanks everybody for your advice, it looks like I am going to have to set it up for the proper wiring, as my wires should not be utilized as proposed for properly setting up this system. I probably will contact an electrician out here in GA, but I am hoping to get this job done for a good deal and done correctly.
Any thoughts on how much it would cost to have this installed and have the wiring altered to the two different variations suggested?
Where are you located?
The Following User Says Thank You to jbfan For This Useful Post:
stickboy1375 (05-29-2013)
Old 05-29-2013, 08:10 PM   #17
I am located in right Near Carrollton, GA.
electricianadv is offline   Reply With Quote
Old 05-29-2013, 08:19 PM   #18
jbfan's Avatar
Rewards Points: 400
Send me a pm.
Old 05-29-2013, 08:27 PM   #19
I attempted to send you a PM, but it said I needed 15 posts to send a PM, so it would not let me. Maybe if you send me a PM it will go through since you probably have over 15 posts.
Gary
Old 05-29-2013, 08:38 PM   #20
jbfan's Avatar
Rewards Points: 400
PM sent.
Let me know if you got it.
Old 05-29-2013, 08:43 PM   #21
Ok thanks, I will check that company out. I attempted again to reply but it wouldn't let me because I didn't have the 15 post. Anyways, I appreciate the advice.
Gary
The Following User Says Thank You to electricianadv For This Useful Post:
jbfan (05-29-2013)
Old 05-29-2013, 09:41 PM   #22
Resi EC
Rewards Points: 252
IMO the wire coming into the bottom of this JB is SE (it's just CU, SE, not AL), they took a piece of 8 or 6-2 w/G and hard wired a FS range?
Gac66610 is offline   Reply With Quote
Old 05-30-2013, 03:30 PM   #23
Sparky
Rewards Points: 510
I agree the feed(bottom) cable appears to be copper SE cable, which if coming from the main panel, would be okay. The bare would be #10 solid if it were NM/romex..
Techy is offline   Reply With Quote
Tags
electrical range , electrician advice , hookup range , range , range installation
Ceiling Fan Installation Electrical Question Rafterman414 Electrical 4 01-06-2013 09:25 PM
Range Hood Installation NeetWork HVAC 0 11-07-2012 11:11 PM
Gas leak on new range installation beamerman Appliances 1 10-25-2009 07:40 AM
Electricl Installation for Electric Tankless Water Heater Educator Electrical 13 07-06-2008 10:27 AM
residential electrical installation dallas520 Electrical 1 05-15-2005 08:51 AM
