Old 07-20-2012, 11:19 PM   #1
electrical question one switch one outlet one fan
My light switch in my room turns off and on half of a outlet to plug in a light. I want to keep that the way it is. From the same light switch can I add some romex to power/turn on and off a ceiling fan.
hurv is offline   Reply With Quote
Old 07-21-2012, 12:25 AM   #2
Master Electrician
yes, if the wiring exists for this to be done. You would need a neutral in the switch box. You would pigtail the black off the switched side of the switch.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Electrical power disappeared from switch to receptacle craighank Electrical 3 02-19-2012 02:06 PM
Combo light switch outlet re-wire question seasidediy Electrical 3 07-21-2011 06:02 AM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
2ft Wall/Hallway Electrical Outlet Question?? hatchekc Electrical 1 07-17-2010 09:51 PM
