Electrical Question/Advice - Electrical - DIY Chatroom Home Improvement Forum
Old 09-27-2008, 02:40 PM   #1
Question
We just moved into our newly built house that has a bonus room above the garage. At the time of development, we didn't think it would be an issue, but now we realize it is an issue. In our bonus room we have a fan in the middle and a mushroom light on either side of the fan. We only have one switch to control all 3 devices, either on or off (and I checked and they are piggy backed on each other to the wall switch). Well, we have a futon up there for overnight guests and we would like to be able to have the fan going with the lights out. What do you suggest we do? There is really no room up there to run additional wire because it is up against the roof line. Our builder said if we wanted to accomplish what we wanted, we would have to cut into the drywall in order to run additional wire. But I wanted to come here and see if someone has any other ideas in order for us to get what we want. Hopefully someone has a great idea, thanks in advance!
jrossh21 is offline   Reply With Quote
Old 09-27-2008, 03:03 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,972
All I can say is someone did NOT think ahead. What a shame.
Either pull chains on the lights or cut the sheetrock.
I would have run "3-wire" across all three boxes.
Old 09-27-2008, 03:52 PM   #3
What can I find here?
Winchester's Avatar
Rewards Points: 150
+1 here
Winchester is offline   Reply With Quote
Old 09-27-2008, 04:33 PM   #4
Well, I guess I have to take some responsibility - we told our builder 1 switch (because we weren't thinking clearly). But no one told us otherwise to avoid a situation like this
So, it's possible to add a pull chain to the mushroom lights? There's 2 bulbs in each mushroom. If that is my only option, I'll do that rather than cutting into the drywall.
Also, do you think a wireless solution could be applicable here? - if it's even possible? Thanks!
Old 09-27-2008, 04:38 PM   #5
1. Cut and patch drywall.
2. Wireless remotes. They make one specifically for the fan/light. If the cable runs sw/fan/lights, it will work with a little rewire. If it runs sw/light/fan/light you will need to find a separate remote that will fit into the light jbox.
edit.......google "SmartHome" and "X-10" devices.
220/221 is offline   Reply With Quote
Old 09-28-2008, 03:48 PM   #6
The cable runs sw/light/fan/light ... so if I were to install a wireless receiver on the 1st light, will it cut power to the fan and the 2nd light as well? Or is that what you were talking about when you said get a separate remote? Can you go a little more in detail about what you were talking about please?
Will this be a good solution to put on the lights?
http://www.smarthome.com/2475S/INSTE...Dimming/p.aspx
Also, does it come with a remote, or will I have to purchase that separately?
I'm very new to wireless and x10, so any links to suggested items will greatly help, thanks!
Old 09-28-2008, 04:38 PM   #7
Here is how it works.
When you leave the switch on (or hotwire/jumper it), there is 120v going to the lights and fan jboxes.
A control module, mounted at the fixture/fan, switches this power on and off with a signal from a battery operated remote control.
You can install a standard fan/light remote (Home Depot/Lowes) which will fit under your fan canopy, but it will ony operate the fan and the second light.
You will need a second module to control the first light. The physical size of a second, standard fan/light module may be an issue as it will need to mount inside the light jbox.
If it will fit, simply leave the dip switches set the same and both lights will turn on fro a single controller.
If you search hard enough you may be able to come up with smaller modules but the standard fan/light remotes are inexpensive and readily available.
Old 09-28-2008, 04:59 PM   #8
Electrical Contractor
kbsparky's Avatar
Is there a "knee wall" area on at least one side of this room? A small crawl space for storage?
One might be able to "fish" some wiring from there up to the ceiling lights to solve this dilemma ....
Old 09-29-2008, 11:49 AM   #9
Actually, there is a knee wall on either side of the room. If I can do it that way, I would only have to run 1 set of wires from the fan to the switch. That would be the best solution. If I find that it can't be done that way, I'll probably do what 220/221 suggested. Thanks for all your suggestions and advice!
Can a homeowner perform electrical work in MA? dpd512 Electrical 77 04-11-2012 06:48 AM
Electrical Box near Shower Valve dasajame Electrical 3 07-07-2008 06:46 AM
2 Prong Electrical mjcongleton Electrical 10 04-16-2008 08:59 AM
Please Help - Weird electrical issue affecting home network sxpsxpsxp Electrical 23 02-03-2008 11:42 AM
OK to put electrical outlet into storage area under stairs? melanie_s Electrical 1 12-29-2007 04:09 PM
