Electrical Question - Electrical - DIY Chatroom Home Improvement Forum
Old 02-23-2010, 08:47 PM   #1
Electrical question
I have no power on the wiring on a GFCI outlet. I tested the breaker and it has power. I also tested all other GFCI outlets and they are working. What could be my problem?
KBarker is offline   Reply With Quote
Old 02-23-2010, 08:55 PM   #2
Just call me Andrew
Rewards Points: 1,020
What exactly have you tested on the outlet that is not working?
How many wires do you see in the box with the outlet and what colors are there?
Andrew
secutanudu is offline   Reply With Quote
Old 02-23-2010, 09:30 PM   #3
Registered User
Termite's Avatar
If downstream receptacles aren't working, make sure you didn't reverse the line terminals and load terminals of the GFCI with your wires.
Electrical Box Wiring Question OmahaGirl Electrical 9 02-18-2010 08:03 AM
Slight electrical current in bathroom faucet water + other unusual electrical events story Electrical 9 09-16-2009 10:28 PM
Electrical wire size question. shawnlee Electrical 11 08-11-2009 06:25 PM
Help needed on electrical question Partisan Electrical 9 02-25-2009 02:00 PM
electrical question scatterbrain General DIY Discussions 1 01-22-2008 06:27 AM
