Electrical Question - Electrical - DIY Chatroom Home Improvement Forum
Old 09-17-2009, 02:16 PM   #1
Rewards Points: 168
electrical question
I will be running electricity from the patio to a new garage(transfering same lights basically).It is about 12ft away.Will i have to use a seperate panel box or is the transfer ok since it will be basically same 2 lights.
It will be run underground .Does this usually require install/approval by certified electrician to pass codes,or can it be installed by the contractor?
Thanks for any info.
hidden 1 is offline   Reply With Quote
Old 09-17-2009, 10:37 PM   #2
If you can, please supply photo's, showing the area were this work
will be done, so the other's can have a better understanding. Please note with
you photo all points of special interest, involving this electrical project.
user62257 is offline   Reply With Quote
Old 09-17-2009, 11:01 PM   #3
Detached garage?
Just running lights or outlets too?
One circuit or two?
You can run 2 circuits as a MWBC
Check with your local building Dept to find out if you can do the work or have to hire an electrician. Usually a homeowner can do the work, BUT someone hired must be licensed to do the work. Local rules apply - so you need to check
Old 09-17-2009, 11:29 PM   #4
Not very good questions, so the answers may not help.
no
Local regulations vary. There is no "usual".
220/221 is offline   Reply With Quote
Slight electrical current in bathroom faucet water + other unusual electrical events story Electrical 9 09-16-2009 11:28 PM
Electrical wire size question. shawnlee Electrical 11 08-11-2009 07:25 PM
Simple electrical question (Amperage/voltage) Badfish740 Electrical 18 01-06-2009 12:35 PM
Basic Electrical Question Dom Electrical 11 12-01-2007 01:42 AM
220? Electrical question coondog7 Electrical 6 11-19-2007 10:04 AM
