-   -   electrical question (http://www.diychatroom.com/f18/electrical-question-53185/)
hidden 1 09-17-2009 01:16 PM
electrical question
I will be running electricity from the patio to a new garage(transfering same lights basically).It is about 12ft away.Will i have to use a seperate panel box or is the transfer ok since it will be basically same 2 lights.
It will be run underground .Does this usually require install/approval by certified electrician to pass codes,or can it be installed by the contractor?
Thanks for any info.
user62257 09-17-2009 09:37 PM
If you can, please supply photo's, showing the area were this work
will be done, so the other's can have a better understanding. Please note with
you photo all points of special interest, involving this electrical project.
Scuba_Dave 09-17-2009 10:01 PM
Detached garage?
Just running lights or outlets too?
One circuit or two?
You can run 2 circuits as a MWBC
Check with your local building Dept to find out if you can do the work or have to hire an electrician. Usually a homeowner can do the work, BUT someone hired must be licensed to do the work. Local rules apply - so you need to check
220/221 09-17-2009 10:29 PM
Not very good questions, so the answers may not help.
no
Local regulations vary. There is no "usual".
