Electrical Question - Electrical - DIY Chatroom Home Improvement Forum
Old 12-06-2012, 05:37 PM   #1
Electrical question
Can I use 14 guage wire for standard receptacles and lighting for a remodeled basement. There is currently 12 guage wire on the old outlets and I have removed them. The main feed coming in looks like 12 guage from a 20 amp circuit. Help!
jbrod26 is offline   Reply With Quote
Old 12-06-2012, 05:45 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Not on a 20 amp breaker.
Old 12-06-2012, 05:48 PM   #3
Rewards Points: 332
I'd use 12ga with a 20A breaker for outlets and 14ga with a 15A breaker for lighting.
sgip2000 is offline   Reply With Quote
Old 12-06-2012, 05:50 PM   #4
Can I change the breaker to a 15 amp
Old 12-06-2012, 05:54 PM   #5
jbfan's Avatar
Rewards Points: 650
Sure you can.
Bathrooms, laundry rooms and kitchen receptacles have to be wired with 20 amp breakers.
Old 12-06-2012, 05:59 PM   #6
So I can pull the breaker and replace it with a 15 amp? Now some of the wire that comes in from the panes would still be 12 guage. Can I use that still as my main source? Run that to a junction box and run the receptacles and lights from there?
Old 12-06-2012, 06:01 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
WHY bother???
Just use #12 for the rest of what you want to do on that circuit and use #14 for anything else.
Old 12-06-2012, 06:08 PM   #8
Then I would have to run a new wire to the electical box in the garage and put a new breaker in to run the 14
Old 12-06-2012, 06:15 PM   #9
TTW
TTW's Avatar
Yes, you can use a 15 amp breaker with #12 wire, you MUST use a 15 amp breaker with 14 gauge. If there is any 14 gauge wire in the circuit you have to use a 15 amp breaker.
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 12-06-2012, 06:28 PM   #10
Rewards Points: 4,796
You can always add a thicker gauge wire. e.g. you can use 12g or 10g on a 15 amp breaker. Just keep in mind the main issue is heat buildup. The bigger the wire, the less heat buildup. The key is to make sure the breaker trips before the wire gets hot.
Obviously if 14g is allowed on a 15a breaker, and 12g is allowed on a 20a breaker, then 12g or 10g is allowed on a 15a breaker because those are even less likely to get hot before the breaker trips than 14g.
You can mix and match all you want, as long as all the wire is rated for the circuit. You can put 14, 12, 10, and 8 (or bigger) on a 15a breaker. You can put 12, 10 and 8 on a 20a breaker. You can put 10 and 8 on a 30a breaker.
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
TTW (12-06-2012)
Old 12-06-2012, 07:09 PM   #11
Then just use #12.
I don't get all this. WHY bother changing wire sizes???
Old 12-06-2012, 07:16 PM   #12
TTW
TTW's Avatar
I agree, use 12, the price difference is minimal if you have to redo it in the future, coupla daughters with blow dryers will prove it to you...
Old 12-06-2012, 07:17 PM   #13
Because I have 300 ft of it. To run a new wire to the breaker in the garage would take alot of fishing to get to the breaker and possibly opening walls to run it. So If half of my basement is a laundry room on 1 20 amp breaker and the other is a room that I am finishing and it had 12 guage wire running thru on a seperate 20 amp breaker. I took all the wiring out and now I have the main lead that comes from the breaker which is 20amp and a lead of 12 g wire. I want to use what I have or it will get even more expensive. So my question is can I change the breaker so I can use what I have or should I just spend more money and buy 12g. I want to run 2 lights and 4 outlets.
Old 12-06-2012, 07:20 PM   #14
TTW
TTW's Avatar
Yes, just pop in a 15 amp breaker, that will work just fine.
Old 12-06-2012, 07:24 PM   #15
Well, this would have been good to know right from the start. All this confusion as to your motives would have been eliminated.
In this case FINE, use the #14 for everything but the laundry and change the breaker to a 15A.
The Following User Says Thank You to Speedy Petey For This Useful Post:
jbfan (12-06-2012)
Need URGENT help with question regarding fixing electrical panel in home asledge Electrical 66 02-22-2013 04:49 PM
Electrical Panel question pattyobrien3 Electrical 19 09-14-2012 11:11 AM
vent hood electrical connection question cbendock Electrical 4 02-12-2011 10:33 PM
Cape Cod Electrical Question jordan83 Electrical 8 01-12-2011 05:59 PM
Electrical Box Wiring Question OmahaGirl Electrical 9 02-18-2010 08:03 AM
