Electrical Question - Electrical - DIY Chatroom Home Improvement Forum
Old 07-07-2012, 04:18 PM   #1
Rewards Points: 14
Electrical question
I have been remodeling a house and unable to get a fan hooked up. I put blacks to black and whites to white. Trips the breaker. So I have been trying to figure this out without a hundred trips (no pun intended) to the breakers. I put together this diagram and wondering if anyone can tell me if this is right... Thanks!
Sent from my iPhone using DIY Forum
ofcjosh is offline   Reply With Quote
Old 07-07-2012, 04:23 PM   #2
MarginallyQualified
Rewards Points: 2,464
The source B/W gets tied to the "who knows where" B/W.
Add a piece of white wire (pigtail) between the W/W wirenut and the fixture.
Tie in the OTHER white wire (that goes to the switch) under the B/B wirenut.
The last black wire (from the switch) goes to the fixture.
Old 07-07-2012, 04:26 PM   #3
Rewards Points: 150
Other than putting black tape on the ends of the switched white wire to indicate it is not neutral, it looks good.
Try it without hooking in the "to who knows load" to see if that might be the problem.
goosebarry is offline   Reply With Quote
Old 07-07-2012, 04:29 PM   #4
Electrician
Rewards Points: 802
Drawing looks right, you should feed the source on the white to the switch and then "back on Black" to the fan. Won't solve your issue but it will be wired correctly.
Where is the joint for "who knows what", the source, and the feed to the switch located.
darren is offline   Reply With Quote
Old 07-07-2012, 05:22 PM   #5
Rewards Points: 14
Awesome, with all your help it's working! Thanks again for all the quick responses!
Old 07-07-2012, 05:23 PM   #6
If the house is old, and has cloth covered wire, it is not rare that the white wire grays a little, and the black wire lightens...especially if they have been subjected to heat from the previous light fixture for years. Perhaps you have inadvertently hooked the white wire of the "who knows" to the hot...or be careful, that the "who knows" part circuit may be "reversed polarity", (done sometime in the past)?
Note: If the switch is off, and the breaker trips when you turn it on, then the "short" is not part of the fan and switch-leg).
kontoose is offline   Reply With Quote
Schedule 40 PVC in Chicago? franwalker Electrical 56 12-20-2011 10:04 PM
vent hood electrical connection question cbendock Electrical 4 02-12-2011 10:33 PM
Cape Cod Electrical Question jordan83 Electrical 8 01-12-2011 05:59 PM
Canadian Electrical Code Question flemingetq Electrical 4 11-25-2010 09:42 AM
Electrical Box Wiring Question OmahaGirl Electrical 9 02-18-2010 08:03 AM
