-   -   Electrical Project Help (http://www.diychatroom.com/f18/electrical-project-help-146042/)
Marsell4k 06-05-2012 05:57 AM
Hi,
I am trying to make something that I think will be basic for most electricians but not for me and need help/advice (in layman's terms).
The project involves a low powered circuit with a sensor/switch that when pressed will reduce power to a solenoid, unlocking something. When the sensor/switch is not touched the solenoid will revert back to its default "locked" state.
I have the switch/sensor and I'm sure I can find the correct type of miniature solenoid, but what else would I need to use exactly and what would connect to where?
Sorry for what is probably a completely basic or stupid question, but I'm likely to bodge this up with getting advice first!
Cheers.
joed 06-05-2012 06:33 AM
You need a power source for the solenoid. The type depends on the solenoid lock.
You should use a solenoid the fails locked. That means when power if OFF it is locked. Otherwise the solenoid will likely heat up from being under power constantly.
