Electrical Problem With A Power Wheels - Electrical - DIY Chatroom Home Improvement Forum
Old 12-29-2012, 08:45 PM   #1
Electrical problem with a power wheels
Howdy, I need some help. I got my son a power wheels for wheeler for christmas and it needed some lights. I installed the lights and decided to use the battery that powers the car. I installed a SPST switch http://rsk.imageg.net/graphics/produ...266162w345.jpg and they work fine. The problem is when i use the switch to power them off the power wheels will not work. Is this due to and open connection? Im sure the power wheels has some saftey feature to kill the battery when this happens. Any help will be appreciated thanks.
Sam
srsheets86 is offline   Reply With Quote
Old 12-29-2012, 09:32 PM   #2
Rewards Points: 6,652
You most likely miswired the switch into the line that powers the foot pedal.
Old 12-29-2012, 09:37 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,970
You'll need to post detailed photos or an accurate wiring diagram in order for anyone to understand what the problem is. We need more information.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is online now   Reply With Quote
Old 12-29-2012, 10:47 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,956
When in doubt, undo what you did and see if it returns to proper operation.
Old 12-29-2012, 10:47 PM   #5
http://www.modifiedpowerwheels.com/f...?TOPIC_ID=2236
Old 12-29-2012, 11:42 PM   #6
dmxtothemax's Avatar
Rewards Points: 5,494
We need to know a lot more ?
How did you wire the lights ?
Where exacitly did you tie into the wiring system ?
How is the power wheels wired ?
Many Many possabilities !
dmxtothemax is online now   Reply With Quote
Old 12-30-2012, 07:35 AM   #7
Rewards Points: 1,536
For a lighting circuit of this kind you would wire the lights to the wires that go to the two battery terminals.
For this project you should not have had to disconnect any of the existing wires. If you did then you probably created the problem that way.
What kind of lamp did you use? Traditional automotive turn signal lamps (let alone headlight lamps) draw a lot of power and the Power Wheels may have a circuit breaker that tripped on you. Or maybe the power draw was enough to melt the soldered connections of too thin wires they might have used and something has now fallen apart.
I am guessing that a Power Wheels would need at least 16 gauge wiring for the motor circuits, possibly 14 gauge. The same wire sizes (14 gauge for 15 amps) apply to 12 volts as apply to 120 or 240 volts. (For long runs, you actually have to upsize for low voltage applications; that's a ong story that is not on topic here.)
Electrical loading question jimcorey Electrical 2 12-08-2012 07:27 AM
Treadmill Electrical Problem jcleary47 Electrical 12 07-05-2012 12:29 AM
Electrical Short - No Power Now Diggyj Electrical 8 01-03-2011 09:59 PM
Payne with power venter problem magicatt HVAC 10 12-31-2010 07:25 AM
Control4 Thermostats Power Problem ?? fluidimagery HVAC 11 12-03-2010 04:36 AM
