Electrical Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 04-08-2008, 09:32 PM   #1
Unhappy
Electrical Problem
I have a light in my kitchen that doesn't work. I tested the circuit with an ohms meter and didn't get a reading with the black and red wire but when I touched the black and ground gsi wire I did have electricity do I have a short?
KolbTwinstar is offline   Reply With Quote
Old 04-09-2008, 08:39 AM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
curious, are you in a country other than the US? The black and red wire thing makes me think so.
If so, it would be extremely important to preface your questions with this info.
Old 04-09-2008, 08:50 AM   #3
Licensed Pro
No short. Burned out bulb maybe?
Old 04-09-2008, 11:27 AM   #4
nap
You talking to me?
nap's Avatar
househelper, notice the 2 colored wires. To me, that suggest 240 voltage and possibly a euro based electrical system.
Along with the the term GSI is unfamiliar to me. I suspect it may be a term used in a euro based electrical system.
So, as such, it would be possible to have power on one leg and get a reading to ground and still not have a light work.
If not the case, OP needs to explain a lot more before anybody can really help. In the US, there should never be a read and a black wire connected to a light in a residential setting.
Old 04-09-2008, 12:50 PM   #5
I'm in the USA
I'm in the USA and yes it is a red and black wire!
Old 04-09-2008, 12:52 PM   #6
Gfi
IT's GFI not GSI.
Old 04-09-2008, 12:54 PM   #7
Bulbs OK
I put three new bulbs in it.
Old 04-09-2008, 02:25 PM   #8
nap
You talking to me?
nap's Avatar
well, you have to tell us what you do have then. There should be a white wire along with some colored wire (other than white or green) attached to the light. You should read voltage with a VOLTmeter when checking between the two with the swicth on.
you say you used an ohmmeter. You need a volt meter. If you actually used an ohmmeter and got a reading between the black and the ground of the GFCI recep, it is pretty much meaningless without knowing other info. You should be able to read through an incandescent light bulb so if the light bulb was in, what you read would be normal.
So, be more specific and explain what wires you have to where and if yo uhave a voltmeter and we'll go for a ride and get you fixed up, hopefully.
Old 04-11-2008, 10:21 PM   #9
voltmeter
Yes, It is a voltmeter and the electrician used the red wire and the black wire to connect to my light switch the white wires are tied together and the black wires are tied together then a black wire tied to the two black wires is plugged into my light switch along with the red wire. I think they have it setup as a two way switch somehow. I used a light tester in one of the plug ends that don't work and it indicates Hot/Gnd reverse.
Old 04-11-2008, 10:48 PM   #10
nap
You talking to me?
nap's Avatar
what wires are actually connected to the light?
Old 04-12-2008, 11:16 AM   #11
joed's Avatar
Rewards Points: 13,266
You probably should connect to the red and white wires.
Old 04-12-2008, 04:18 PM   #12
Waht ?
220/221 is offline   Reply With Quote
Old 04-12-2008, 10:21 PM   #13
What a mess!
I get power to my light if I connect the black wire and the ground wire!
I get power at the light switch if I connect the black wire and the ground wire. What is going on?
Old 04-13-2008, 01:37 PM   #14
Put down the tester and slowly walk away.
Put down the bong too.
Old 04-13-2008, 09:08 PM   #15
lol .
nacko is offline   Reply With Quote
Self induced electrical problem :( domiflichi General DIY Discussions 7 07-10-2008 08:33 AM
Major electrical problem!? Rexkwondo Electrical 7 02-06-2008 04:13 PM
Mystery Electrical Problem sippin Electrical 14 11-07-2007 10:42 AM
electrical outlet problem ? BEN17 Electrical 1 07-29-2007 06:23 PM
Perplexing electrical problem prglor Electrical 4 05-30-2007 02:20 PM
