Electrical Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 07-06-2013, 05:12 PM   #1
Electrical problem
Hi all,
I live in a condo. I am having kind of a weird. Last night I was washing down my patio. I heard a pop and the 3 outlets along the wall that separates the interior from patio stopped working. Also the outlet on the patio, the one outside the front door, and the two bathroom lights stopped working. The outlets in the bathroom still work as well as the vent fans. Just the light bars above the sinks stopped working.
The pop I heard sounded like a GFI. I have a surge protector that I plug my TV and other equipment into so I think that was what I heard. My TV, etc are all fine.
Nothing on the electrical panel seemed to have been tripped but I tried resetting them anyway. I also checked all the GFI's and they seem to be ok. So I am at a bit of a loss as to what is going on. Iím guessing I got water into the outlet but it seemed pretty dry when I checked it. It is also enclosed in a case with a hatch to protect it from the weather.
Any ideas would be appreciated.
nvguy is offline   Reply With Quote
Old 07-06-2013, 05:20 PM   #2
MarginallyQualified
Rewards Points: 2,464
Spend $5 on an outlet tester.
Get the one with the button (that checks GFI's) on top.
Old 07-06-2013, 05:21 PM   #3
actually i think i have one of t hose i just forgot about it. the GFI's in the condo have a light on them and a TEST button. when i hit the text button the light comes on then i push the reset button and it goes out.
Old 07-06-2013, 07:15 PM   #4
An old Tradesmen
Rewards Points: 7,318
Moved to Electrical forum.
Old 07-06-2013, 07:22 PM   #5
Rewards Points: 6,652
Most likely the pop you heard was a wire blowing off the back of a backstabbed outlet, or junction point blowing apart.
Old 07-06-2013, 09:53 PM   #6
" Euro " electrician
frenchelectrican's Avatar
Hi all,
Check your outdoor receptales for cracked gasket or loose cover those are famous for tripping the GFCI's.
Those are pretty common issue with GFCI with outdoor receptales.
Merci,
Marc
Schedule 40 PVC in Chicago? franwalker Electrical 56 12-20-2011 10:04 PM
Do I have a major electrical problem? teamcampreder Electrical 12 07-30-2011 09:33 AM
wife tried to fix electrical problem :-\ mikahtx Electrical 14 08-11-2010 01:35 PM
Electrical receptacle problem centralhome Electrical 13 12-27-2008 01:45 PM
Electrical "arcing" problem? morden5b Electrical 17 12-17-2008 06:10 PM
