Electrical Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 06-21-2013, 04:05 PM   #1
Electrical problem
All my 120 volts outlets read 240 volts when i take a reading with my volt meter. Taking the reading from side to side on the outlets. But when you plug something in the outlet nothing works.
SERVICE EXPRESS is offline   Reply With Quote
Old 06-21-2013, 04:17 PM   #2
Pro
Rewards Points: 91
Call an electrician immediately, and don't plug things in.
CarpenterSFO is offline   Reply With Quote
The Following 4 Users Say Thank You to CarpenterSFO For This Useful Post:
J. V. (06-22-2013), Kyle_in_rure (06-21-2013), SERVICE EXPRESS (06-21-2013), Speedy Petey (06-22-2013)
Old 06-21-2013, 04:25 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,820
AS BOB SAYS IMMEDIATELY....AND IF IT is all your circuits (you can test with your multi-meter, but donj't plug stuff in, actually I go around and unplug TV etc.)... Call the POCO...They will respond immediately.
MTN REMODEL LLC is offline   Reply With Quote
The Following 2 Users Say Thank You to MTN REMODEL LLC For This Useful Post:
Old 06-21-2013, 04:45 PM   #4
I check the main breaker with volt meter from the terminal to ground reads 120v on each side . Then check main breaker across the two terminals reads 240v
Old 06-21-2013, 05:11 PM   #5
Pro
Rewards Points: 91
Call an electrician before you or someone else gets hurt or killed. I have nothing more to say about it.
J. V. (06-22-2013), Kyle_in_rure (06-21-2013), MTN REMODEL LLC (06-21-2013), SERVICE EXPRESS (06-21-2013)
Old 06-21-2013, 05:33 PM   #6
Resi EC
Rewards Points: 252
Agreeing with everyone call power company, they will check their end of things.
Call an electrician, make sure they can come out if power company says their end is fine.
It sounds like you lost a neutral some where, if you haven't guessed by now this is dangerous.
If at first you don't succeed .... do not work on live electrical
Gac66610 is offline   Reply With Quote
The Following 2 Users Say Thank You to Gac66610 For This Useful Post:
Old 06-21-2013, 08:24 PM   #7
Thank Ya Gac... Guess this is a reson to not try skydiving
Old 06-21-2013, 11:03 PM   #8
" Euro " electrician
frenchelectrican's Avatar
Have you called your POCO allready ?
If the POCO say ok on their side then get a electrician to come in and I have a very strong feeling that the netural is super serious compreised so as other poster posted to you.,, turn it off or unplug everything much as possible.
This part is not a joke at all I have see some serious damage with it.
Let us know the outcome of this situation.
Merci,
Marc
Old 06-22-2013, 10:05 AM   #9
Rewards Points: 160
If you are not concerned with your safety, do you like your electronics?
They will all be fried if you do not heed the advice given on this forum.
Bye Bye TV, DVD, Computer, appliances. You name it, you could find yourself replacing all these things.
Pull (turn off) the main breaker and wait for a professional.
Old 06-22-2013, 10:08 AM   #10
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
It's either an open neutral on a multi-wire branch circuit or an open service neutral.
Either way, not a typical DIY repair.
See previous replies.
Speedy Petey is online now   Reply With Quote
Old 06-22-2013, 10:10 AM   #11
Resi EC
Rewards Points: 252
maybe too late
Wonder why the OP has not replied back
hope he has a laptop and WiFi
Old 06-22-2013, 10:15 AM   #12
Yea.... Depending on your load configuration, a lava light will really lite up... maybe even explode!
I'm sure / hopefull you are aware of the danger from all above here!!!!
But, come on back after the electrician/poco is there and let us know how you lost a neutral.... just for our education and experience.
TIA
Best
Old 06-22-2013, 10:23 AM   #13
Speedy.... Yea... and in my opinion.... it was smart of everyone to not start diagnosing for him and advise going pro on it.... but interesting sorta contradiction in what he said:
1) He said ALL recepticals went 240 (ie service neutral) BUT
2) Then said he MM'd service entrance and got 120 from hots to ground/ neutral (ie service fine and just a branch circuit)
To me, would be interesting to find out.... just curious.
Best
Peter
Schedule 40 PVC in Chicago? franwalker Electrical 56 12-20-2011 10:04 PM
Do I have a major electrical problem? teamcampreder Electrical 12 07-30-2011 09:33 AM
wife tried to fix electrical problem :-\ mikahtx Electrical 14 08-11-2010 01:35 PM
Electrical receptacle problem centralhome Electrical 13 12-27-2008 01:45 PM
Electrical "arcing" problem? morden5b Electrical 17 12-17-2008 06:10 PM
