Electrical Problem - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-09-2013, 02:45 PM   #16
electrical Problem
Thank You All for helping me. I got all the lights to work in the kitchen. Now I have one problem. The Three-way switch that goes in the four switch box works, but the one that goes to that in living room don't work. I hate to change any in the kitchen. How do I get it to work.
Because I have the three-way switch working in the kitchen to dining where the four switch is located. because I got the travels right in the kitchen,because I have to other boxes that have two single switch that connected to it and they work also. So what is my problem?
Liz Shaffett is offline   Reply With Quote
Old 04-10-2013, 07:53 AM   #17
joed's Avatar
Rewards Points: 13,740
Old 04-10-2013, 07:56 AM   #18
joed's Avatar
Three way not working is usually caused by the wrong wire on the common screw. If you did not mess the other switches then the problem is in the kitchen.
Old 04-10-2013, 09:17 AM   #19
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Was the first switch a 4way? Why is the red spliced to the white? How many total hot wires are in the box? It looks like a white wire was cut from the splice, why? What is the wire with the white tape?
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 04-19-2013, 07:07 PM   #20
Electrical Problem
guys i thought i had it solve but i'm still having problems with the three way switch. I'm tired of fooling with it. The only reason I'm doing it because my husband been out sick and money tight.I can't afford someone to come in. so I keep trying to get it to work. I figure out each light and fan wire, and common wire. But the I can't figure out the travel wire when i get to the third switch and thats the dining room light. what happens when i connect the dining room light the fan light operates it also. so i cant get pass that.
Please help me again!
My husband only one able to work. I'm disable. That reason why we can't afford a electoral person.
Liz
ps. I put the picture from photo bucket.
Old 04-19-2013, 07:09 PM   #21
I put it on hoed by accident. the picture is there.
Old 04-20-2013, 06:18 AM   #22
joed's Avatar
Click on the little upside down envelope looking icon and put the link to your picture in the box. The picture will then show up here.
Old 04-20-2013, 11:40 AM   #23
Thumbs down
Red and white are cap off because we had a ceiling fan in the dining room. But we don't know. Just a light .
Old 04-20-2013, 11:43 AM   #24
White tape is on the one because it went on all the three switches after first one for the ceiling fan light and I only have one hot wire from the panel.
Old 04-20-2013, 11:47 AM   #25
No the first one was a three- way and the hot wire was on the second one and they had a piece of wire that went to that the first one stuck in the hole where the common screw is on the switch.
Do I have a major electrical problem? teamcampreder Electrical 12 07-30-2011 09:33 AM
Electrical Problem RSpoto Electrical 12 02-13-2011 01:20 AM
wife tried to fix electrical problem :-\ mikahtx Electrical 14 08-11-2010 01:35 PM
Electrical receptacle problem centralhome Electrical 13 12-27-2008 01:45 PM
Electrical "arcing" problem? morden5b Electrical 17 12-17-2008 06:10 PM
