Electrical Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 07-08-2011, 03:40 PM   #1
Electrical Problem
I have a GFCI circuit that is giving me fits. The entire series of wall plugs went dead, and the GFCI would not reset. I wrongly assumes that the GFCI outlet was bad, and repalced it. There is a green light that illuminates on the new GFCI outlet, so it is getting power from somewhere, but the plugs are still dead - including the GFCI plug. I am really confused as to what is going on. ANy ideas?
Planny is offline   Reply With Quote
Old 07-08-2011, 04:29 PM   #2
Electrical Contractor
kbsparky's Avatar
Some GFCI outlets illuminate when it is tripped, so that seems normal to have a light lit, while no power at the outlets.
I would first disconnect the load wires, and see if the unit will reset, and at least power up at the GFCI outlet itself.
From there, connect your downstream outlets back into the circuit, one at a time. This will help isolate where the problem(s) may be, so repairs can be made.
-KB
Old 07-09-2011, 01:13 AM   #3
Rewards Points: 506
Seems odd that a green light would indicate a tripped GFCI. A red light yes?
Old 07-09-2011, 01:31 AM   #4
Rewards Points: 6,652
Depends on the manufacturer. I have one that lights Amber when tripped. One that shows Green when active, but no light when tripped. One out in the garage is Red when tripped, but no led when active & working. Again, depends on the manufacturer. Most of mine are Leviton's, but the one in the bath is a Paslode Pro-series.
Old 07-09-2011, 01:39 AM   #5
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
It may protect an outside receptacle downstream. Check and make sure no water is getting into the box. Also verify the line (in) and load (out) are wired correctly.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 07-09-2011, 02:06 AM   #6
I and probably everyone else, wants to know how you deduced that, just from a couple of sentences that the OP typed out in their request. You have no way of telling what the problem is, same with everyone else here that is throwing ideas out, and places to check to find out.
The way you find out what the problem is, is by using a six step way of solving the issue. And due to no one is there to see what the problem is, we all have to go by what little they have given. IT is the same way that a police detective solves a crime.
Old 07-09-2011, 02:26 AM   #7
electures's Avatar
It was a thought and a suggestion based on my own experiences. Notice I started my sentence with "It may". Thought the purpose of this forum was to help people figure out what the problem is and how to correct it. Guess I am missing something.
Old 07-10-2011, 11:30 AM   #8
Okay, figured it out. Turns out my head was between my butt cheeks when I installed the new GFCI. I reversed the input leads.
A bit embarrassing for sure, but I have a feeling that this has happened to many people many times before me.
The lesson learned here - Always double check your work.
Old 07-10-2011, 10:17 PM   #9
electures's Avatar
Guess I got lucky.
Electrical Problem RSpoto Electrical 12 02-13-2011 02:20 AM
wife tried to fix electrical problem :-\ mikahtx Electrical 14 08-11-2010 02:35 PM
Slight electrical current in bathroom faucet water + other unusual electrical events story Electrical 9 09-16-2009 11:28 PM
Electrical receptacle problem centralhome Electrical 13 12-27-2008 02:45 PM
Electrical "arcing" problem? morden5b Electrical 17 12-17-2008 07:10 PM
