Electrical/pressure Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 04-01-2011, 05:25 PM   #1
electrical/pressure switch
replacing a pressure switch on an Ingersoll Rand compressor (220 volt, 15 amp 60 gal.) got the new switch with no wiring diagram, with four tabs on top and two grounds what is the order of motor(black wire, white wire) and the power (10 gauge) black wire, white wire?
pleslie is offline   Reply With Quote
Old 04-01-2011, 05:56 PM   #2
I=E/R
a7ecorsair's Avatar
How was the old switch wired? The new switch should have some labels like L1 and L2 and T1 and T2. Do you see this anywhere?
a7ecorsair is offline   Reply With Quote
Old 04-01-2011, 08:49 PM   #3
Yes the Tabs are marked from left to right L1-T1-T2-L2
The old switch had numbers instead marked 1-6
Which correspond?
Old 04-01-2011, 09:20 PM   #4
I=E/R
a7ecorsair's Avatar
There isn't a diagram in the cover of the pressure switch? I'm going from memory - the power goes to T1 and T2 and the motor to L1 and L2. I might have a switch in the garage I could go look at.
Old 04-01-2011, 09:47 PM   #5
No diagram,
The old switch had the motor going to 2&4 with a screw and power to 1&3
with the new switch I'm going to have to solder ends to go into a blade, I'll try the motor on L1 and L2 and see what happens.
Old 04-02-2011, 04:28 PM   #6
Rewards Points: 506
It's a switch. When closed, L & T are connected.
L1 and 2 are power. T1 and 2 are motor.
jlmran is offline   Reply With Quote
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 07:25 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 10:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
